AirForceAngler
Aug 07, 2014Explorer
hddecker wrote:jungleexplorer wrote:
Well, looks like I am not going anywhere. Got everything all hooked up and took the trig for a test drive. I did not make it 7 miles from a cold start before my transmission hit 200 degrees and I had to pull over to cool off. And this is on flat ground and I do not even have water in the tanks yet.
I think I need a stronger TV.
Sounds to me like you have a trans cooler that has a problem.
Are you servicing your transmission as per the manufacturers service schedule. Eirty fluid tends to create havok with coolers.
Were you towing in OD or in 3rd?
44,068 PostsLatest Activity: Apr 17, 2021
