myredracer wrote:
There's no way the actual payload will anywhere near close to 2051 lbs for a 1/2 ton. For example, the actual payload capacity of our 3/4 ton is 1800 lbs, a lot less than the 2800 lbs the sticker says. Never use the figure on the sticker....
Did you read what I said or just look at the picture? I said he likely has less than 1200 pounds of payload. My 3/4 ton Suburban has 2051.
You are the only person that said the Tire and Loading sticker is inaccurate. I'll stick with the recommendation to use it for estimating.
