OP just joined and asked for guidance in the subject line and gets responses of accidents and lawsuits? We all must remember we started one day not knowing what we needed to know and that's why people come here...not to be chastised.
To the OP in my experience there a 3 groups of trailer haulers. Those that go strictly within the ratings using numbers that they all weighed or calculated accurately. That is the safest method but takes time and diligence. Then there are those that use published and guesstimates to have a rough ideal and can be near or slightly over their limits and then there are those that just hitch and go mostly over all of their limits but since it pulls and stops think that they are okay. I would suggest the first group.
Now on to your scenario the others are saying you are probably close or over your payload rating which typically is the rating that limits the weight of a trailer first. To figure out if you are within the payload specs of your truck you need to know:
1. The payload for your truck
2. The pin weight for the 5th wheel trailer loaded
The pin weight is the weight that the 5th wheel pin exerts on your 5th wheel hitch. I never owned a 5th wheel but towed a bunch of different ones for short trips. My way to calculate was to take 25% of the actual weight of the trailer but that is a rough figure. I don't know if your trailer has the pin weight placarded or can you get it from the manufacturer but those published numbers are for an empty trailer and you have to try to figure out yours loaded if you want to be more accurate.
That pin weight plus the weight of your 5th wheel hitch has or should be less than the available payload for your truck.
The payload of your truck should be stated on the yellow sticker in the door jam but if not if can be calculated by using your GVWR and subtracting the empty weight of your truck. That is the available payload.
I have a scale to measure the tongue weight of my conventional trailers but don't know how others derive their actual pin weight maybe they can share here.
This calculation only addresses the GVWR of the truck or the payload of the truck not necessarily the GCVWR which is another way of limiting the weight of the trailer. With the GCVWR you need:
1. Loaded truck weight
2. Loaded trailer weight
You add those 2 numbers together and they should not exceed the GCVWR of the truck.
Now depending on the weight of your trailer you should make sure you don't exceed the load capacity of your tires. I use 1/2 the actual loaded vehicle weight (weight on rear tires) plus the pin weight and that is the load that is directly on the rear 2 (or 4 for DRW) tires. The trucks load distribution isn't 50% on front and 50% on rear but this is my approximate. You can look on the tire and see what is its maximum load capacity and multiply that number by 2 if you have single rear wheel (SRW) and that will tell you the load capacity for the rear tires.
You should also make sure you don't exceed the axle rating but in my experience that is the last limit you will hit when loading. That is also on the yellow sticker as GAWR for rear axle.
GVWR-Gross vehicle weight rating- the max weight of the vehicle loaded with occupants (and pin weight for trailers)
GCVWR-Gross combination vehicle weight rating- the max weight of the loaded vehicle and loaded trailer
GAWR-Gross axle weight rating-maximum weight the axle can support
Hope this helps
