bobndot
Mar 23, 2016Explorer II
After they sit for a time, they can sometimes do that. Light the stove for a minute to make sure you are getting gas flow.
Leaving one burner on, while looking at the flame, try to fire up the WH again .
The stove burner flame should remain the same. If the flame dies down, I would suspect a low pressure problem at the regulator on the propane tank.
here is more info for you.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24529271.cfm
44,027 PostsLatest Activity: Mar 05, 2025
