Old-Biscuit
Oct 26, 2014Explorer III
Gene&Ginny wrote:RV daytrader wrote:You beat me to it. DON'T cut anything, just unscrew the white fittings.westend wrote:
You need to remove the two (red/blue) supply lines. The nuts with the tabs holding the faucet against the underside of the counter top will then untwist off of the faucet's threaded supply pipes.
Bingo...give this man a cigar!...dont know why some are saying to cut the lines!
Exactly........
The hot & cold water lines are crimped to connectors that screw onto faucet stubs which are also used to hold faucet tight to counter by use of those wing nuts.
UNSCREW pipe connectors.........unscrew wingnuts
Reverse to install new faucet.........might need new washers for inside the pipe connectors
44,029 PostsLatest Activity: Jan 28, 2025
