bdpreece
Oct 26, 2014Explorer II
RV daytrader wrote:westend wrote:
You need to remove the two (red/blue) supply lines. The nuts with the tabs holding the faucet against the underside of the counter top will then untwist off of the faucet's threaded supply pipes.
Bingo...give this man a cigar!...dont know why some are saying to cut the lines!
X3
You may have to pull down on the red and blue lines while you unscrew the connectors but they will come off. Then and only then can you remove the upper plastic knobs.
44,025 PostsLatest Activity: Feb 06, 2025
