mobeewan
Oct 27, 2014Explorer
Do not listen to anyone who says to cut. The faucet connection stems are threaded all the way the entire length. When you put the faucet in place with the threaded stem connections through the counter you put the wing nuts on like in the picture and tighten them against the bottom of the counter. Then you connect the tubing adapters on the end of your tubing like in the picture to the threaded faucet stems. The adapters will have conical rubber seals inside the nuts that will seat against the ends of the stems as you tighten the nuts (see sheet5 step 10). The seals are replaceable if you need to.
I replaced my faucet with a nice Moen Caldwell that I got at Lowe's.
44,030 PostsLatest Activity: Jan 21, 2025
