APT
Jul 19, 2018Explorer
Do not get a hybrid unless you want to sleep under canvas. You should be good for nearly any TT under 6000 pounds dry if you have the HD towing equipment. $15k new is tough, but there is a crowded market in the $20-25k range. I would recommend used for your first time, say 3-7 years old. There no brand to avoid, i.e any clearly better than others. Quality is relatively low across the board. So focus on floorpla,n floorplan, and floorplan. If buying used, you are buying the owner and how well it was maintained. Water is the most expensive enemy, as most other issues are relatively inexpensive to repair/replace.
44,066 PostsLatest Activity: May 13, 2026
