Butch50
Jul 19, 2014Explorer
skipro3 wrote:
Other than the near interference with the tail pipe, does the rest of the sway bar install look correct to you? If so, perhaps you can adjust your tail pipe for some more clearance.
Mine, (See sig for truck info) hits upon very low/stall rpm speed and shutting off, but not any other time, so I call it good.
It's a good excuse for a new exhaust system at the least I would say! Ha!
I'm sure just about any muffler shop could re-form/mount the tail pipe and get the clearance you need for about $50 or so. The improvement on my truck has me recommending a way to get yours to work for you.
Good luck!
Skip,
The rest of it looks like it would work just fine. I have already been looking to see if I could modify my exhaust. I know one solution that would work is bring the exhaust out in front of the rear tire. It would cause a 90* bend right where it comes out of the catalytic converter. Don't really want to do that but it would work.
