Mello_Mike
Jul 24, 2014Explorer
wintersun wrote:
The Ram 3500 trucks starting in 2013 got the new and much stronger and more rigid frame. No reason to think that an anti-sway bar is needed for this truck (or a 2011 and later GM truck).
If you are getting sway the first thing to investigate is the air pressure in the tires. Second thing is whether the rear springs are able to support the weight of the camper, and not only when it is on level ground but on side sloping terrain as when making tight turns in hilly areas where more than 50% of the camper is loading one side of the truck and its suspension and tires.
Not true. The frame is stronger, but I still have noticed a big improvement in sway with the camper mounted. Before I really had to watch my speed on turns especially going down twisting mountain passes. That is no longer the case. Not only that, but I get very little "pull" from the big 18 wheelers when they pass me on the interstates. I'm running 80 psi on the rears and 60 in the fronts. My camper is only 3,000 lbs which puts me a good 600 lbs under the max payload. My Big Wig was money well spent.
