schlep1967
Jul 26, 2022Nomad
I would work to get everything I could out from under the walls with a screwdriver/chisel/needle nose pliers. And then slide a piece of new flooring under the wall. The new piece only needs to be as wide as the wall. Then you can lay a whole piece down inside that covers everything else. caulk the edges between the two pieces when putting together.
