blt2ski
Jul 16, 2013Moderator
If as donn mentioned, you load up the rig, weigh it, if it is at gvw, then you have NO tow capacity! unless you want to tow a trailer with no hitch wt!
There is not a what is comfortable as far as what you are asking. There are a couple of "rule of thumbs" besides staying under gvwr for the truck and trailer......
IIRC max length is 110" wb for 20', then add/subtract a foot of length per 4" of wb.
I use a max trailer weight of 2x the grawr.
Then use the gcwr as a guide per say. Then again, I also had and have a truck where the gcwr is lower than its gvwr! I guess I can not load to gvwr?!?!?!?!?!
BEST max trailer by lbs, is weigh the truck ready to go with people etc. Take the remaining payload to gvwr, divide by expected hw%, and you have max trailer you can tow. So if you have 1000 lbs left over, you have a max 10K ball mount trailer with 10% HW, or 4000 lbs if you tote a 5w with 25% hw! If the tow rating is under these amount, that that is your max warranty tow rating available to you!
Marty
Marty
44,056 PostsLatest Activity: May 04, 2014
