First, I do not normally say 'sure you can', or 'no you can not', but
provide the metrics for you to figure it out yourself. If you are
only looking for confirmation of what you want to hear, you will not
get that from me, but will get tons of it from others....along with
specific metrics that might be out of context for you so it will
seem very confusing
Comments in red embedded in your quoted question and the last quote
from another thread with a diagram of how the ratings systems work
in concert (it is a system) and than maybe you can see that some of
folks take a single component (rating) out of context as an absolute
Gerald1755 wrote:
I'm sure this question has been covered multiple times before so please forgive me. I have the following truck and I am trying to decide what would be an appropriate trailer to purchase. I understand that the payload includes all passengers cargo in truck and hitch weight. What I would like to know is what would be a comfortable weight and length trailer to tow. I am thinking somewhere between 25' and 28'. Is that a good range? What about max gvw of trailer? 6,000-7000? Any help would be greatly appreciated.
2011 f-150 4x4 super crew 145"wheelbase
Longer wheel base than
my 3/4 ton Sub, but the crew will work against you here
I no longer subscribe to older rules of thumb for TV wheel base vs
trailer length. Technology for tires, suspension, etc have changed
that and it's really up in the air, as it is dependent on what
you have, which hitch system (which bars you have vs actual weights,
how you set it up, etc, etc) where you tow and how you drive (your
talent and style of driving...like me..heavy foot boy racer)
5.0l v8 6spd auto
3.55 gears
7200 gvwr pkg
Regular half ton and married with the crew cab
works against towing heavy
1560 payload
This is based on the OEM's 'curb' weight and only has one 150lb driver
and the tow option.
Unless you have that stripper model and only weigh 150lbs, then that
1560 lb payload does NOT apply to your TV
Reference the below diagram to make sense of what I just said
Below quote from another thread from a newbie asking similar question
and normally all ask similar but in a slightly different way.
Why I always recommend going out and weighing your TV axle by axle,
both empty and fully loaded ready to go camping. Including all people,
pets, ice chests, cargo in/on the TV.
That is the only way to know for sure where you are in reference to you
TV's ratings.
BenK wrote:BenK wrote:
Below is my diagram showing how the specifications/limits/ratings system works
Best to weigh your setup axle by axle fully loaded ready to go. If you don't
have one or the other, then use their GVWR's as the potential max...if you load
everything like most do...few are truly light in the stuff they load
Also, decide if you believe in the ratings or not.
If not, then do whatever but a new 2013, assume still under warranty. so know
that if they find out over loaded, warranty might be denied (I would if I was
the OEM)
If yes, then check out the below diagram, gather the specifications for 'your'
TV and plug in the actual weights to do the simple math.
You have found out that it is not all about go, but the ratings are the true
measure. You will get tons of 'sure you can', etc, etc advice, but there is only
one person responsible for the setup and that is the driver, who might not be
the OP, but a buddy or spouse. Then the OP should ask themselves if the advisers
would pay for any overload break down?
I do not advise with the 'your are good for it', 'sure you can', 'no you can not'
but provide the metrics for the OP's to figure it out themselves...I have to
sleep at nite as I take providing advice seriously...
This is NOT a half ton can't tow anything...everything can tow
and then they also have specifications/limits/ratings on what they
are 'rated' to tow.
Just that half tons have lower ratings and head room than bigger trucks
Then note that there is a huge spread on 'half tons'. From less than
6.2K GVWR to over 8.1K GVWR (I call them fake half tons). So many
get bit by hearing/reading of a 'half ton' doing whatever but miss
or the poster didn't say they have one of those fake half tons. I've
gotten several PMs about that and one guy so mad he wanted to sue the
guy telling everyone a half ton can, but he had one of those fake
half tons...so this guy who PM'd me burned up his diff towing what
he though all half ton's can because one guy said he does and advise
that guy he too could...
another thread titled: New guy needs helpBenK wrote:
Welcome to the forum !
First decide if you believe in the OEM specifications/limits/ratings or not
If not, then do whatever but note that if there is warranty left...the
OEM may be denied. If no warranty, then you have taken the OEM off the
liability hook
If yes, then read up and ask lots of questions
There is a huge difference in how a question is asked or answered
'Can do' is way different from 'should do' or 'rated for'
The specifications, limits and ratings is a 'system' and most take
a single rating as an absolute or out of context....like your reference
to your TV's MTWR (Max Tow Weight Rating)
Meaning that, those MTWR's are only a true rating within the fine
print of the OEM's specifications
Meaning that they derived those MTWR's from a 'curb' weight TV, which
is the 'stripper' model with no options other than the tow option
and one 150lb driver. Some full fluids, others partially filled
Best is to weigh your TV's fully loaded...axle by axle. That is the
only way to figure out your 'true' MTWR
You should gather these ratings for both your TV's
GVWR
FGAWR
RGAWR
GCWR
Then do the simple math to figure out your true MTWR
Some come here looking for confirmation of what they want to hear
or what they have already decided on....they WILL get many advisers
that will do exactly that...just ask yourself if those advisers will
provide the funds for warranty or whatever cost an overloaded TV
might suffer
This image shows how the ratings system looks like in graphical formhowmuchcanitow
howmuchcanitow
