JrStafford
Aug 11, 2020Explorer
Need help with Dometic Duo Therm Air Conditioner
Just picked up a really nice 2000 Lance Lite. Slight issue with the AC, it works TOO GOOD! It will absolutely freeze you out, and after it runs for a couple of hours, it will start slowing down to the point that it eventually overloads the Generator and shuts off. What I found, is that during this situation, the lines and the compressor are COMPLETELY covered in ice! Let it thaw, and it'll work fine for a bit.
The info I found online says usually one of 2 problems: Condenser or evaporator are dirty (they are not on mine), or freeze sensor is shot. I can't find a freeze sensor on mine. I did find a picture online that shows a Duo Therm that looks just like mine, and there appears to be a sensor in the side on the (condenser or evaporator?, not sure which it is). Here is a picture of mine. You can see the hole on the left, but nothing in it. Also is a small plug down below that's empty. And also, there is a pink and a white wire that has been cut, just hanging.
Can anyone with a Duo Therm around 2000 verify that I should have a sensor in that hole? And if so, does it plug into the empty spot down below?
Empty plug down below:
