BurbMan's avatar
BurbMan
Explorer II
Dec 10, 2014
Need Help with Mystery Leak
In the process of working on a skylight leak over the shower, I went into my underbed storage to retrieve my toolbag, only to find it soaking wet on the bottom. I had also cut a piece of that thin grey trunk liner to cover the vinyl floor in the storage area and it too was soaked. My jack boards had wicked water about 3" up (they are 1/2" plywood and were standing vertical). The canvas chair on the bottom of the stack was soaked. A few cardboard boxes were mush.
So I emptied out the storage, put stuff out in the shed to dry, and dried the vinyl floor. It may look a a little wet in the pics, I had just toweled it off.
The storage area in question is under the queen bed in the front of the trailer, with pass-thru hatches on either side.
So the TT has a one piece fiberglas front cap, and the seam at the top was just inspected in late summer. I had put eternabond over that seam a few years ago so it was in good shape.
Looking at the front wall (with the lights on it in the pic) there is no wetness or staining on the wall. Those light marks you see I think are scuffs in the wallpaper from loading stuff, they are dry to the touch. Same with the walls up above in the bedroom wardrobe cabinets, so I don't think the water is coming from the top.
I had also just replaced the weather stripping on the two pass-thru hatches this summer, so I don't think it's coming in there....
DW was questioning if anything had spilled etc, and I don't store any liquids in there. The carpet dripped clean water into a bucket, and there is no odor, mold or anything else to indicate that was/is an ongoing problem. Last camping trip was about a month ago and all was fine.
The storage has been open and airing like this for a few days now, and it's dry as a bone even though it's been raining.
What am I missing here???? Where did all the water come from???
  • My first thoughts would be the two largest openings in the wall to the storage area. Those are the compartment doors. These have questionable seals at best and rain under pressure from wind or travel could permit a lot of water into the compartment. Replace or bolster those door seals.
  • Bath is in the rear of the trailer and the vent pipes are mid-ships over the galley. It's not in storage, just in the yard and sits pretty level.
    Schlep, I had the same thought. I did tow in some rain, but not really heavy rain. Wondering how I could test for this...maybe have to get the garden hose out, but I hate to spray up, these trailers are sealed that good on the bottom.
  • Just a couple thoughts.
    How far is that bath sky light from the storage compartment?
    Has the TT been in storage for a while & was it level or did you have it tongue down for water run purposes?
  • Did you tow it while raining? You would be amaized at hoe they can leak "up" when wind is pushingthe water in.
