rexford
Aug 22, 2013Explorer
Here is the schematic.
http://www.barkermfg.com/vip3500.pdf
I have the same unit and I believe it is grounded by using an external tooth (scratch) washer
with one of the MTG bolts?
First thing I would do using your meter is make sure there is +12V at both switch pins when toggled.
Using the schematic test GND pin to black wire pin and GND pin to red wire pin
If 12 volts at pins work towards motor
If no 12V work towards battery
44,029 PostsLatest Activity: Jan 21, 2025
