rowekmr's avatar
rowekmr
Need Help with TowLite
I just bought an 1998 TowLite hard-shell pop up from local auction with worn out placard so don't know the model. It is a collapsible TT with hard shell (pop-up?) and wanted to know how to raise the roof/sides? It is still on their lot and will get it and take it home to try to check it out fully.
Thanks
  • You can use battery power or shore power to raise top . Inside of door is a switch to raise top. When top is raised, push to lower and top will drop on a lock to keep top from falling if you lose hydrolic pressure. When you want to lower top, push the up button to raise top off of lock, then pull chain to release lock and push the down button and top will lower.
  • I looked at pictures on the internet and it looks like one my friend had 30 years ago. I think there was a switch inside the door that raised and lowered the roof. So obviously you would have to have a battery in it or plug it into shore power.
  • You bought a old, old pop up without popping it and inspecting?
