tcgg's avatar
tcgg
Need Help
Need your help please.
I connected TT electric power source to house outlet for about 3 weeks. Lights inside TT such as bathroom, living room or should say anything that runs on 12 volts works fine. When disconnecting electric from the house none of the lights or anything requiring 12 volts works.
I replaced the 12 volt battery with a brand new fully charged one and still don’t have lights,etc that works using 12 volt battery source. What do I check or replace now?
  • Depending on make and model most trailers do have battery connect switch but if your doesn't I would definitely start at the battery and work my way back. what happens when you plug into your tow vehicle.
  • Start at the battery and check your ground wire where It attached to the frame. Remove and clean before replacing. From there just start following the power from the battery with your volt meter or a 12 volt test light (make sure light/meter has a good ground as well)
  • popeyemth wrote:
    get a meter and check your fuses and connections.
    learn to use a meter before you throw any more money at the problem.
    Sounds like your converter is working. You get 12 volt when plugged into shore power. No 12 volt from battery power.
    After you've checked the main fuses (30 amp), in the fuse panel, and you're sure they are good, look for one of these. It, or, they (could be more than one if you have a slide out) will be mounted up under the trailer frame, somewhere near the connection of cable coming from positive side of battery.
    Could also be a bad connection where positive battery cable connects to the trailer. Could be bad connection on negative battery cable to trailer.
  • I have never installed a battery disconnect and almost positive it did not come with one preinstalled. If it has one I have never seen it.
  • get a meter and check your fuses and connections.
44,056 PostsLatest Activity: Nov 19, 2013
