siamese
Jul 24, 2017Explorer
afidel wrote:
You're not towing anything near 9k lb with an SUV unless it's a 2500/3500 Suburban.
What SUV do you have and what is its payload capacity?
EDIT: Rte 1985, your response came in while I was typing my response.
Ah, yes, that's exactly the question I had when I read your posting,
My wife and got back into trailering this summer. We had a Honda CRV and a Ford Focus. Neither vehicle could possibly tow, so we had a clean slate. We decided to replace the Focus with a tow vehicle that could double as my daily driver (mileage that wouldn't be really bad).
We settled on a Ford F-150, with the twin turbo v6, which will tow about 12,000 lbs. It's as much truck as we wanted to tolerate (cost, mileage, etc.), and we chose a trailer that would be compatible with it.
We went with a Jayco 26bh bunkhouse, no slides, and dry weight around 4900 lbs. I'm real comfortable with our total package. Ample power, ample wheelbase, and the trailer doesn't weigh too much more than the truck.
Forgive me if you already know this, but on your trailer quest, floor plan, overall size, amenities, and brand preference are important, but topping the list by a wide margin is correctly sizing your tow vehicle to your travel trailer's loaded weight and tongue weight.
When we went looking for our tow vehicle, and opted for the F-150, we carefully chose the engine, transmission, and final gear ratio. The 3.5L V6 puts out 375 hp, and 470 ft. lbs. of torque, through a 10 speed transmission (with factory cooler), and a final gear ratio of 3.55. What a rig. Most of the time, we can just select "tow mode" for the transmission, set the cruise control at 62 mph, and it loafs along at 1900 rpm in 8th gear.
The math: fully loaded maybe we're creeping up on 7000 lbs., and we're "rated" for 12,000. That might seem very conservative, but when you factor in trailer weight vs. truck weight for handling and braking, we think it's about right.
You'll get some useful information from this site if you provide your:
--make, model, and year of your tow vehicle
--engine specs
--transmission cooler?
--tow rating provided by the manufacturer
--rear end gear ration
--transmission / auto?...how many gears
--wheelbase
--weight of vehicle
I will not be surprised if others have more to add to the list.
Our truck and trailer package cost about 55k. A mountain of goodies from Amazon that included a Briggs and Stratton generator at $630 and replacing the POS battery charger (that come with a lot of trailers) for about $200, plus towels, leveling equipment, etc., probably came to around 2.5k.
Moral of the story: Let's get your tow vehicle capabilities squared away so you can effectively pick the right trailer.
44,070 PostsLatest Activity: Jul 01, 2022
