6_6_Oilburner
Jul 31, 2018Explorer
rtreptow7 wrote:6.6 Oilburner wrote:rtreptow7 wrote:
Thanks. I did take it to the dealer for service. In fact it was scheduled to go in the following week for a recall on the axle nut. Something like checking the torque on the rear axle nut. I called and told him about the fluid and he said to bring it in right away and they would take a look at it. Glad I did.. They said the failure wasn’t related to the recall
So...your rear hub was loose and leaking oil, and it ruined the differential...... but it had nothing to do with the recall to check the spindle nut torque? Granted, the story has obviously got multiple layers of getting passed along from the tech, to the service advisor, then your words.... My guess is that it was direct result.
I'm certainly no mechanic, but I was thinking along the same line you were that there had to be a correlation? I was told that if it was a loose axle nut the gear oil would have been all over the outside of the wheel, not the inside? But like I said, I'm no mechanic. Once I get the truck back and talk with the service guy again and see the paperwork, I'll update this too.
The nut sets the bearing preload, the axle shaft its itself seals that outer area from gear oil leaking out, it would most certainly leak at the hub seal and inside the wheel with the nut loose. Sounds like the service write is either ill informed or just diverting to make it seem like they were separate issues.
