SilnJohn wrote:
Carlisle Tires are also what Lippert agreed to install on mine, I just decided to spend a little more and pay the diff between Carlisle and Maxxis. So anyone going through this don't accept anything less.
Am in the same boat as those of you on this thread as our 2013 Shadow Cruiser 280QBS has 2200 miles and the same clearly visible inside wear problems. Have the same bad H118ST 14 inch tires too. Have taken the camper in to have the axles and tires addressed under warranty. Fingers crossed.
I've seen it mentioned to consider upgrading to Maxxis. Is this the one most are using/recommending? ST215/75/14 D rating (1870 lbs @ 50 psi)
What is the new model of the replacement axles being used and what size is found there? Is it another Lippert replacement?
