Caryite wrote:
I've seen it mentioned to consider upgrading to Maxxis. Is this the one most are using/recommending? ST215/75/14 D rating (1870 lbs @ 50 psi)
What is the new model of the replacement axles being used and what size is found there? Is it another Lippert replacement?
Wish you the best, seems like several more are joining this club every week.
My 3500# axles were replaced with 5200# made by Lippert. I can tell you they look like tree trucks compared to the 3500# twigs. I used load C tires in the stock size, I didn't know if the upsize would work on the stock rim/clearance. Most of my travels are within 200 miles or less and load C still left me some room so I felt confortable. If I did long distance traveling I probably would have tried the up size.
