Bowfreak's avatar
Bowfreak
Need new tow vehicle suggestions
I currently own a base model 2009 Tacoma 6cyl 4X4. I am a long time Toyota guy and this is my 5th on in 30 years of driving. I love the way they drive, feel, solidness, and how bomb proof they are. When I ride in friends Chevy and Ford trucks they seem to rattle more and just don't feel as solid.
We just purchase a Trailmanor 2720SL camper that the dry weight is around 2800 lbs. My truck is the base package without the tow package. So currently only has a 3500 lb towing capacity. So I would be close to that capacity with actual weight. My truck only has a payload of about 1600 lbs and with the gas, 2 people, extra **** we load in the bed, camper shell, and tongue weight we are going to be pushing the total payload and tow capacity.
Since I have had this truck for 6 years I thought about trading it in. Thought about going up to the Tundra but the gas mileage sucks on it and since this will be my daily driver as well I would like something with a little better gas mileage than the Tundra since I put about 20,000 miles per year on my truck.
When I got to looking around I found some reviews on the new Colorado diesel that is coming out in 2016. Love the idea of a midsize truck that pulls as good as it will and the gas mileage they are expecting. It also will retail for about what a new Tacoma with the tow package will retail.
I currently get about 22 mpg in my Tacoma (not towing) and really don't want to go backwards on mileage. However, I want a truck that can hold up to the miles I put on one. I usually run my trucks to about 150,000 before I trade them in on a newer model.
Give me some suggestions on trucks to look at and if you own one what mileage you are getting.
Thanks
  • The Colorado has a decent motor. It is a version of the VM Motori A428. My liberty has the VM Motori R428 motor, and pulled a full profile HTT without major issues, including 3500 miles in 2 weeks this summer.
    I will throw out the Ram 1500 EcoD and V6 Pentastar motors. The Ram rides great (even better with air ride). The Pentastar is a decent motor, and should do fine with a trailmanor. The EcoD will do better, but more expensive. Some will argue about the payload. Towing my HTT, full load of people, and stuff from the bed that use to be in the camper with the liberty, I am probably over payload. But, I am waiting to hear someone say that it is more safe for me to tow with the Jeep at GVW than with the Ram slightly over GVW.
  • That is why I said it would be pushing the 35000 tow capacity as I knew all the extra stuff would add up from the dry weight to push the 3500 total tow capacity. The 3500 lb rating is because it's the base model and didn't have the tow package which takes it up 2000 lbs. the only thing the tow package adds is hitch, 7 pin plug, engine and transmission cooler, heavier battery and alternator. I have already installed the correct hitch, added 1500 lbs helper springs, brake assist, and a 7 pin harness. I can add a engine/transmission cooler for around $175 if I do it myself.
    With that being said the new 2016 Tacoma with the tow package installed from the factory has a 6800 lb tow capacity and a 1440 lb payload
    Dry weight of my truck is just under 41000 lbs. GVW max for my truck from the sticker on the door jamb is 5700 lbs which is right at 1600 lbs for payload. It also matches my owners manual.
    So a new Tacoma would be an option.
    Please keep in mind this is a Trailmanor hard sided pop up so it doesn't tow like most travel trailers.
    SouthpawHD wrote:
    First of all, you can't use the dry weight of the trailer - there's propane, battery, water, gear, etc that you will be traveling with. The dry weight is the weight from the factory before anything is added to it. No one travels dry.
    So let's assume you travel light and add a mere 700 pounds to that dry weight, for a total of 3500 pounds. Assume 12% tongue weight (12% is standard) and you'll be around 420 pounds tongue weight. Now add maybe 400 pounds of human weight, 300 pounds of stuff in the truck and you'll easily be around 1,100 pounds of payload.
    Does your Tacoma really have 1600 pounds of payload???? That amount is better than some 1/2 tons.
    So with that, I think 1600 of payload capacity is acceptable (however, I do not believe your Tacoma has enough power to adequately pull all that or enough braking capability to stop all that), but it all depends on how much you pack and how many passengers you have. I would definitely be looking at 1/2 ton trucks and the Tundra is a fine truck for that (but they do suck the gas).
    FWIW, I get about 14-16 MPG (combined) in my 5.3L GMC Sierra. I can get in excess of 20MPG on the highway. About 10-12 towing.
    Good luck with your search.
  • I just sold my 2010 Tundra DC SR5 to get a 1 ton dually diesel due to the 5th wheel I am purchasing. My Tundra with tow package and 5.7 got 16 to 17 MPG around town and I could squeeze 20 to 21 out of it on the highway if I kept my right foot under control.
    And the Tundra does make a great daily driver.
    Towing the trailer it got between 8 and 10 MPG, but I don't think the TrailManor will bite into the mileage that much as it does not have the huge sail effect of a regular trailer.
  • I have a diesel truck I use to tow our trailer and use a Toyota Avalon as my daily driver...best of both worlds.
  • You need to research newer v-8 1/2 ton trucks.
    Most can get 20mpg highway.
    I have a 2007 Chevy Avalanche, which is heavier, and I often get 20mpg highway.
    Towing will always be 9-11mpg towing, with a gasser.
  • First of all, you can't use the dry weight of the trailer - there's propane, battery, water, gear, etc that you will be traveling with. The dry weight is the weight from the factory before anything is added to it. No one travels dry.
