woodhog
Mar 05, 2015Explorer
We have a 2006, pull with 2004 Dodge in Signature.
I would convert your truck into a one ton 3500 by adding the
overload springs, it will then be the same vehicle as the 3500.
Then add a set of Torklift Stable loads to take out any squat and side to side rolling...
Weigh the whole outfit ready for camping and then decide if your tires will carry to load. If not go to a higher load bearing tire....
You will then have a perfect ride....
The Stable loads and the swaybar made our ride very well...
Make sure the camper has not leaked if stored outside, look under the
wings, (the aluminium unscrews), pull out the drawers, pull up the closet bottom and look in that area, pull the mattress, settee cushions etc, check to see if water has ran down the outside of the gray tank vent pipe into the closet...look it over really well...
They make a really nice camper and are the best for customer relations of all the manufacturers.
