4bearhug
May 22, 2014Explorer
BurbMan wrote:
Tire rating is a safety issue, pure and simple...running tires overloaded could cause them to fail and unexpected or violent tire failure could dump the whole rig in the ditch.
The rear axle rating is almost always 2x the tire rating. Generally axles themselves in 2500/3500 trucks are rated at 10k+. Front axle ratings are hard to exceed unless you have the 5er hitch mounted like an air scoop.
GVWR has a longevity component to it...exceeding GVWR won't make the wheels fall off, but stuff will wear out faster then it was designed to.
GCWR has a performance component to it, meaning that you want the rig to do a respectable job on hills and on-ramps, not that you are winning races but so you are not going so slow that you pose a danger to others.
If you want some real opinions, post the numbers....
You asked for numbers so here they are.
Tires 3195 ea. (x2) 6390
RAWR 6010 actual 5520
FAWR 4800 actual 4100
GVWR TV 9000 actual 9620
GVWR 5er 14,056 actual 13,300
GCWR 20,000 actual 20,460
payload 2400 actual 3000
TV 2006 Dodge 2500 Laramie CTD crewcab shortbed 4x2
44,056 PostsLatest Activity: May 04, 2014
