StirCrazy
Apr 06, 2024Moderator
is your unit solar ready? that looks like some I have seen that are solar ready where you can plug portable panels into it. use a multi meter and see if you have battery voltage on the port. if you do you can use it either way I would imagin
- HBeil1May 16, 2024Explorer II
Yes it's 12v, and one rv dealer also believed it to be a solar plug with possibility of plugging in portable solar panel. The manufacturer (Riverside) has not responded to my numerous calls for help with this id, or, the specs or requirements of compatibility.
