gmw_photos
Jan 29, 2014Explorer
To the OP, you are running into the age old same problem that many others have: the first limit you run up against on these 1/2 ton based vehicles ( Armada based on Titan )is payload and rear axle capacity.
Forget the mythical "tow capacity" and pretty much forget anything a salesman ( car or RV ) says to you.
So....the first question you need to answer in your own mind is, do you consider the truck manufacturers stated limits to be actual "limits", or are they just "guidelines" .... "suggestions".
Lots of folks run around with tow vehicles overloaded. Up to you to decide if that is wise or not. It's your family.
44,068 PostsLatest Activity: Jun 21, 2026
