summitpower wrote:
So not trying to sound stupid but, my truck will haul 7180, I weigh 220 and wife is 115 all 3 kids combined are 100, I wouldn't travel with water tanks full, and if we take dogs we would take 2 vehicles...also I didn't plan on going to 3/4 ton next year...just was going to get different ram with a V8
Executive summary says both those TTs are waaay to much for your 1/2 ton V6.
You don't understand weights yet. Before you lay out the cash you need to do more research until you do. What are you going to do when you buy a TT that is way too much for your truck and learn on the way home that your truck is inadequate? Or if you lose control somewhere. Or if you find you can't make more than 30 mph up a hill? Do you have a spot at home to park it for a year while saving up for a new truck?
The majority of 1/2 ton trucks have a limit of around 7,000 actual wt. and that's with a V8 and decent diff. gears. We used to tow a 5,000 lb actual weight TT with a 1/2 ton V6 (non-turbo) and it was painfully slow and under-powered. You need to post info. on your truck so you can get more useful comments - year, engine size, long/short bed, reg/ext./crew cab, 2WD/4WD, rear end ratio, etc.
Most dealers are shady or plain ignorant and will say anything to get a sale. The salesman may *seem* like the kinda guy you want to invite over for a Sunday dinner, but they are a wolf in sheep's clothing. Wait until you have warranty issues that need to be fixed and you find out how incompetent they are, flat out refuse to do some things or take 4-8 weeks to do even simple repairs. A dealer can turn the best TT out there into a nightmare and when you find out, there's nothing you can do. Some factories are useless for helping owners too. Investigate the quality of a dealer before purchasing from them. A dealer's prime objective is to make a sale and that's it. Never let them install a WDH for you either.
NEVER, EVER buy a travel trailer based on factory dry weights. EVER. As mentioned above, they are totally useless and can get you into serious trouble. Use the GVWR figure which is the max. a TT can weigh (due to limitations of the frame and suspension). Some TT manufacturers don't list a GVWR like in the Dutchman aerolite 282dbhs so you need to take the cargo carrying capacity of 1307 lbs and add it to the shipping weight of 6293 to get 7600 lbs GVWR. The Shadow Cruiser has a GVWR of 7635 lbs. Both have a length of around 32/33'. Very few 1/2 ton trucks can handle those and need to be properly optioned. You might look at the truck's GCWR too (total truck and trailer wt. rating).
Added weight of all your cargo in a TT (sewer stuff, chocks, BBQ, clothes, dishes, food, books, some tools, etc., etc. plus propane tanks and batteries) can add around 700 - 1500 lbs on top of a factory UVW. A published UVW figure won't include options you've ordered. This is another reason why it is very important NOT to use a UVW dry weight number for a trailer's weight. The Shadow Cruiser has a much higher CCC (2,000 lbs vs. 1307) and is one reason to choose it over the other. It may have a stronger frame and suspension. Just one full holding tank could add 100-200 lbs of tongue wt. depending on where tanks are located.
Payload capacity of a tow vehicle is waaay more important than it's
towing capacity. Focus on payload capacity. If you intend to use the 1/2 ton truck for towing a TT, take it to a scale fully loaded up and subtract it's weight from it's GVWR to find out what weight of TT it can handle. Actual payload capacity can be a lot less than what's on the sticker sometimes, especially if you've added non-factory options. Fully loaded means with all passengers, pets and "stuff" you'd have loaded into the truck for a camping trip. Added passengers, pets, stuff, etc. can typically add something like 400-1,000 lbs to a truck.
Then there is tongue weight... Tongue weight is typically around 12 to 13 percent of the actual weight of a TT. Both of those TTs will have a tongue weight around 900 - l,000 lbs. Then add to that the weight of the passengers, pets, and "stuff" - say it was 1,000 lbs. Then allow 100 lbs for a weight distributing hitch (WDH). Now your total payload added to the truck is 2,100 lbs!! That is definitely 3/4 ton territory.
More on weight... This is for the more experienced (screwed) TT owner or those wanting to be more cautious. Axles have a max. weight rating on them. They have a sticker with info. that will tell you. Tires also have a max. load rating and is indicated on the sidewall. To get the actual weight sitting on the axles, take the estimated tongue weight and subtract that from the GVWR and for both those TTs will be about 6600 lbs. If they have 3500 lb axles, they are loaded to near capacity and will put you at risk for problems like bent axles. If those TTs have 15" load range C tires (LRC) they will have a total max. load rating of 7280 lbs. That leaves 10% reverve load capacity on the tires which the absolute min. you should have. More like 20% is better so you won't end up with premature failure or blowout. If available as an option, order load range load range D tires which would put you at 10,120 lbs total load capacity.
If your going to be using ST tires, you need to learn how to treat them as they need to be treated differently than passenger car ("P" rated) or light truck ("LT" rated) tires. Stay below 65 mph, never tow under-inflated and ensure they are not overloaded (slides can cause that) otherwise you can/will end up with a blowout.
Then there is the whole subject of WDHs and what to choose and how to set one up to minimize sway and optimize handling. Get it wrong and you could end up with a disaster.
