bs49's avatar
bs49
Need some immediate help - will my truck carry camper
I have a 2008 Chevrolet Silverado 3500HD Long Bed Dually Diesel pickup (I had forgot to mention it is 4x4). I purchased it specifically to carry a truck camper and pull either my 16 foot Tracker Aluminum boat or flat tow my Jeep 2 door wrangler.
The camper I am negotiating is a 2007 Okanagen 115TNT 11 foot. It's dry weight is 3600 lbs and has a generator. I'm thinking wet is 4500 lbs. The sticker in my glove box states a truck camper limit of 3050lbs. I calculated my payload at 4030 lbs. I assume I will have to add air bags and a sway bar. I have E rated tires.
Will I be able to pick it up and drive it home using my stock truck and then add everything I need to carry safely? I have a Happijack tie down kit installed but will eventually install a Torklift Superhitch with truss extension and the torklift back tie downs that install on the hitch. So I will have Happijac fronts and Torklift backs.
I am supposed to finalize negotiations tomorrow.
My other option is a 2015 Palomino HS-2902 9 ft if I find the Okanagen too heavy.
