Leeblev
Sep 15, 2015Explorer
I would add: Do you have slide locks? Usually they are adjustable poles that go above the slide wall (when in) and brace against the wall of the unit. This holds the slide in place while you are driving. If you don't, I strongly urge you to get two or three 1x2s and cut them 1/2" longer than the span between the wall and slide, when in. Slide them in to the wall and then tight against the inside of the slide in the front, middle and rear. The slide locks are available at a dealer and should have come with your unit.
44,056 PostsLatest Activity: Nov 19, 2013
