SoundGuy
Feb 28, 2016Explorer
campersmd wrote:
My current inflator will not reach (15 foot max) and I'm not even sure if it will inflate to trailer tire PSI's.
Will I have enough juice in the trailer battery to inflate the tires using the trailer electrical outlet?
That's how I do it. I wired the 12 vdc tire inflator's cable with a standard 7-pin Bargman connector (Pin 4 is +12 vdc, Pin 1 is ground) then made up an extension cable using 12 gauge zip cord, wiring the two ends with Bargman connectors. I also have a short adapter also wired with Bargman connectors that allow me to change the sex of the extension cable. Sometimes I power the inflator by plugging into the truck's Bargman connector, other times I may plug into the trailer's Bargman connector. Works just fine.
