CaveRun's avatar
CaveRun
Need To Adjust The Slide-Out On A Salem TT ?
I have a 2003 Salem LE 29-BHSS by Forest River. . The slide-out has the dinette and the sofa.
The slide-out needs adjusted so it will fit better when its in. . On the left side, its against the wall and the top is too.
On the right side its against the wall, but the top is out about 2-1/2 inches.
Does anyone have a link on how to adjust the slide-out ?
This is my first TT with a slide-out, and I don't know what to adjust.
I can take pictures if needed.
Thanks!
  • downtheroad wrote:
    Go to this link..then scroll to the bottom and you will find what you are looking for...manuals for lots of slides and how to operate and adjust them...hope this helps...
    Click HERE
    Thanks for the link!
    You guys have been helpful, and I appreciate it!!!
    Bill
  • calewjohnson wrote:
    What kind of slide is it? If it has cables, Accu-slide, the adjustment manual is readily online. I can point you in that direction.
    Cale
    It has cables and its hydraulic.
    The only thing I don't see on mine is the synchronizing room travel bolts on the tubing.
    Thanks!
    Bill
  • Go to this link..then scroll to the bottom and you will find what you are looking for...manuals for lots of slides and how to operate and adjust them...hope this helps...
    Click HERE
  • What kind of slide is it? If it has cables, Accu-slide, the adjustment manual is readily online. I can point you in that direction.
    Cale
