Grit_dog
Jun 11, 2020Trailblazer
Andrewmart wrote:
Good thoughts.
Can ya'll help me understand payload capacity. I know what it is, but I'm thinking of payload in the context of Excursion vs 2500 Suburban.
Both are on HD chassis with full floating rear axles, etc. The payload is GVW rating (class 2 sub 10klbs in the era of trucks you're looking at and for regulatory purposes, not capability based on the components or construction of the vehicle) minus curb weight. Prolly has a 9kgvw rating and weighs about 7500lbs.
Excursion has lower "rating" because it's pudgier than a suburban.
Realistic payload with little to no suspension mods is more like 2500lbs+.
Payload (within reason) should have zero bearing on your choice of 3/4 ton SUVs for your uses. You're looking for an old truck. Buy the lowest miles and best verifiable condition you can for your money. Brand and "ratings" are quite a ways down the list of important things when buying old and used.
(As long as you stay away from the 6.0 diesel and 6.5 diesel GM if you're looking at 90s Suburbans)
