Dave_Pete
Jan 24, 2015Explorer II
I appreciate all the responses. I too prefer the pocket screw method except for the one drawback, that of removing so much material from the plywood while making the pocket. And after making the pocket there is only approx 1/2" of plywood to pull on and attach to the framing below. But in truth I guess it really is a minimal amount removed, and it may be an adequate thickness remaining - however weakened, and since nobody has commented on that issue perhaps I am concerned for no good reason.
Alternatively, as stated, it may well be too difficult to locate the center of the plywood by screwing in from below, and of course the screw threads can push the plywood apart, causing splitting. But consider that the original floor was only attached on these edges with the sheet metal strapping and I'll also add the metal, and there is great support and strength on the sides with the carriage bolts, so there isn't as much strength needed in the screws as maybe felt by most of us, especially since this will be a minimally used "hanging" strength, rather than a normal "sitting support" strength.
Then again the rest of the camper is attached into the plywood, due to the nature of the roof/sidewall assembly, so going in from the bottom may simply be following the pattern. Those screws will be every 3-6" and there is a run of rubber gimp between with the screws that are meant to pull the materials tight into the gimp. In some of the rest of the camper I have pre-drilled the attached pieces larger to allow the screw to pull the "attached" tight into the "attachee". Attachee?
The splitting issue has been tested out in another post. Meaning the splitting might not be too big a concern, especially since although it's a #8 screw (for the length) I planned a 5/32" pre-drill instead of the 1/8" being used for the #7 screws.
Yes, the screws are more brittle than other designs but are probably strong enough for the overall method - every few inches where nails were originally used (for the walls edges anyway). And yes, rust (corrosion) compared to stainless, that's been discussed and I hope I made the right decision weeks ago, but time will tell.
So then if minimal strength per fastener is actually needed,then perhaps my concerns about the thinner attached thickness for the pocket screws is unwarranted. (thought bubble).
Glue? Yes, I love glue, and it is in many important places throughout the camper. But it won't be here because I'm attaching assemblies. I have to think of that guy coming after me, if you know what I mean. Most of the camper is being built to allow dis-assembling in major pieces for future rebuilding or repair. And there is the rubber gimp at the joint so the wood on wood doesn't exist anyway. The cleat idea is good too. But I've been finding the floor jack putting pressure from below seems to hold things tight enough while fastening. We'll see on these spots.
Full length metal strap as opposed to several smaller straps? Yes, I kinda like that idea. I was thinking along those lines too. But I wonder if the thicker is necessary. I bought that aluminum flashing weeks ago for such use, planned to double thickness it to reach approximately the thickness of the original straps, which were scrap siding. I have a third neighbor building part of a camper and he used some of my flashing and was plenty pleased with the results of a single thickness. He expressed to me the belief of plenty of strength because of no shear pressure. The pocket screw jig is his btw.
And the pocket screws on hand are anti-corrosive coated, better strength and lifespan than the gold construction (sheetrock) screws.
Someone mentioned they were enjoying the rebuild threads, good that makes me happy too.
So I guess I'll do the pocket screw method. Overall I agree, it really seems to be the preferred method of the two.
Thanks again for all the input. As said in The Money Pit, "The camper is going to be great!"
44,066 PostsLatest Activity: May 13, 2026
