Rangerman40 wrote:
stro1965 wrote:
So, I was on the fence about adding airbags to my SRW. Is the DRW likely to need them? Will it sag as much as an identical SRW? I know the payload capacity is almost double but is that because of the tires and axle or is the suspension heavier?
I have about a 4K pin weight on my 3500 MegaCab dually and it squats enough to level the truck. Unloaded the rear rides a couple inches higher than the front. No need for airbags IMO.
X2. The Ram duallies come standard with overload leaves.
