blofgren wrote:
Rangerman40 wrote:
stro1965 wrote:
So, I was on the fence about adding airbags to my SRW. Is the DRW likely to need them? Will it sag as much as an identical SRW? I know the payload capacity is almost double but is that because of the tires and axle or is the suspension heavier?
I have about a 4K pin weight on my 3500 MegaCab dually and it squats enough to level the truck. Unloaded the rear rides a couple inches higher than the front. No need for airbags IMO.
X2. The Ram duallies come standard with overload leaves.
I'm pretty sure all DRW trucks come with overloads, not just ram.
