monkey44 wrote:
I couldn't find the 1500 with the 6.2 option, I thought that only came on the 2500HD ... but some other stuff I couldn't find either.
Here is the press release (if I am reading this correctly that engine may only be available in the higher trim levels but the max trailer package is available with the 5.3 engine):
DETROIT – The 2014 Chevrolet Silverado 1500 and High Country and the GMC Sierra and Sierra Denali 1500, available this fall, with a 6.2L V-8 produces an SAE-certified 420 horsepower (at 5600 rpm) and 460 lb-ft of torque (at 4100 rpm), the most power of any pickup engine and torque of any light duty pickup truck engine.
The 6.2L V-8 available for Silverado LTZ and High Country and Sierra SLT and Denali models also delivers class-leading maximum available trailering capacity of 12,000 pounds when properly equipped.
Along with power, now comes strong fuel economy as EPA estimates for the 6.2L V-8 EcoTec3 engine technology enable 2WD Sierra and Silverado models to achieve 15 mpg city and 14 mpg city for 4WD. EPA highway estimates are 21 mpg for 2WD versions, and 20 mpg for 4WD models.
"Power and towing capacity are fundamental capabilities for full-size pickups," said Jeff Luke, General Motors Executive Chief Engineer for full- and mid-size trucks. "The 2014 Silverado and Sierra deliver unmatched power and towing capability with a host of ingenious driver aids."
The optional Max Trailering Package is available on 2WD and 4WD V-8 crew cab and double cab models and includes:
-Trailering package with seven-pin and four-pin connector
-Enhanced cooling
-Automatic locking rear differential
-Heavy-duty 9.75-inch rear axle with 3.73 ratio
-Increased-capacity rear leaf springs
-Revised shock tuning for increased control
-Integrated trailer brake controller.
In addition to the 6.2L V8, Silverado 1500 and Sierra 1500 will offer a 4.3L V-6 SAE-certified at 285 horsepower and 305 lb-ft of torque and a 5.3L V-8 certified at 355 horsepower and 383 lb-ft of torque.
