Tyler0215
Apr 21, 2015Explorer
You are not over reacting. This NEEDS to be fixed. Either the axels are out of alignment or the frame is bent. Either problem will cause excessive tire wear. Plus you can't see what behind you on the one side. Take a measurement from the tire to the front of the trailer on each side. I bet they're not even close to the same.
