JIMNLIN wrote:
Some of the '03/'14 3500 SRW Ram packages have up to 12400 GVWR with 7000 lb RAWR and show a 4640 lb payload with the 68RE or a 4470 lb with the Aisin Laramie/Longhorn crew cab long bed 4wd 3.42 gears. http://www.rambodybuilder.com/2013/docs/ram/rammlup3500.pdf
Much much better tow/haul numbers than your older 2500 truck that handled the trailer to your liking. Looks like a good match.
Thanks for the link I was not able to get it to open when I google it but it works from your link. I know I am on the line for the weight on the rear tires once the hitch is added in there but sure would like a 20' truck rather than the 21' truck with a wide bottom. Would like to here from anyone that is using the srw 2013 with a larger trailer.
