I just installed an ac unit and am trying it out to make sure it is working properly. The compressor doesnt seem to be coming on. Now the degrees here is currently 55.f so could this be why it doesnt ...
have you measured any current draw yet. This is the 11000BTU Roof Mounted Air conditioner you was referring to in a previous post.
Curious what the current draw ended up being... I know you was wanting to use the 2KW Honda to run it. I have seen the 9500BTU unit being offered but not the 11000BTU model.
Be sure to post some info once you get it up and running on how it works with the 2KW Honda type Generator...
