pianotuna
May 14, 2020Nomad III
valhalla360 wrote:pianotuna wrote:valhalla360 wrote:
When it gets really hot, the park electrical systems tend to start going out because everyone is running the air/con. Even if it doesn't go out, you can get damaging low voltage.
If the power goes out, crank up the genset and you still have air/con.
Or one can correct the low voltage issue with an autoformer.
Already have one but have still seen voltage drop below 105v with it boosting. Also, it doesn't help when the entire circuit goes out.
The autoformer I use can handle a lower input voltage. Lowest I've seen is 100. Output voltage was above 107 (I don't remember what it was). I'm supposed to be able to use it down to 90 volts input.
