valhalla360
May 15, 2020Navigator
pianotuna wrote:
The autoformer I use can handle a lower input voltage. Lowest I've seen is 100. Output voltage was above 107 (I don't remember what it was). I'm supposed to be able to use it down to 90 volts input.
I was referring to the output voltage when I said 105v. I don't think you'll see much lower than because usually the main park breaker will be popping before it can drag the voltage much lower.
If you want to burn up your electrical system with low voltage, go for it. I'll break out the generator and deal with the consequences.
