RobertRyan's avatar
RobertRyan
New Anti Sway system being introduced in 2020
New Dexter Tow Assist safety system available mid-2020 for fitment to new caravans
A production version of Bosch’s high-tech, anti-sway trailer system with anti-skid braking is finally set to hit the market in mid-2020.
A collaboration between Bosch Australia and DexGo Global, which markets the AL-KO and Dexter trailer stability systems, the new Dexter Tow Assist system provides automotive-style anti-lock braking (ABS), an odometer function, as well as automotive-compatible sway mitigationAL-KO said the trailer anti-lock braking feature utilizes “the most performance out of each trailer brake while reducing the risk of tyre skid or lockup and improving manoeuvrability to avoid obstacles”.
Bosch demonstrated its anti-lock trailer braking feature back in 2017, while both AL-KO and Dexter have offered sway mitigation systems on locally-built caravans for a number of yearsBringing ABS technology to caravans and trailers in Australia is long overdue and has been eagerly awaited by both the public and manufacturers,” AL-KO Managing Director Australia & New Zealand, Peter Mannfolk said.
“AL-KO is proud to be able to deliver this to the market in conjunction with Bosch, and we look forward to being able to offer a new level of safety and a more enjoyable towing experience to consumers,” he said.AL-KO says the built-in odometer function in Dexter Tow Assist “provides valuable mileage tracking” to assist with maintenance intervals, while the sway mitigation feature "keeps the trailer in-line without any driver input. The system intuitively knows when to apply braking, maintaining trailer stability, without significantly reducing speed or skidding the tyres”.
Dexter Tow Assist will be available to Australian RV manufacturers for fitment to new, electric braked caravans from mid-2020, with aftermarket upgrade kits to follow.
The system includes a Tow Assist control module, power-axle wiring harnesses, indicator light, Nev-R-Adjust brake fitted with wheel speed sensor and brake drum with ABS tone ring cast-in...
  • It's better because it goes on the trailer and hopefully wont just bring it to a screeching stop like the vehicle systems do.
  • A similar system has been on the aftermarket for a few years now, maybe 5. It uses a gyroscope? Mounted on the trailers A-frame. The brakes are wired independently into the control unit, then it sends the signal to control each wheel independently if needed. It's not a bad idea. I belive the factory integrated controllers only pulse the trailer brakes (as a set of 4) instead of independently.
    However this system sounds like it's even better because it's fitted with speed sensors at each wheel.
  • Lwiddis wrote:
    How is this better than is currently offered on GM Tahoe, Suburban and trucks?
    This system SHOULD be light years ahead of the GM system, which doesn't upgrade any of the TT brake hardware....
    But I bet it won't be cheap.. I am sort of suprised that it is not a disc brake system though.... Yeah, I realize that drums are 99% of the TT market. Still it would be nice if it had a disc brake option
  • How is this better than is currently offered on GM Tahoe, Suburban and trucks?
