patperry2766's avatar
patperry2766
Explorer II
Jun 26, 2017
New battery already bad??
2013 Ford F-150 5.0.
I replaced the battery Friday. Started the truck up great for the rest of the day.
Started up fine Sat AM, but after sitting at work all day Saturday, it kinda slow cranked.
This AM, I had to jump start the truck to get to work. I've gone out a couple of times today to make sure it will start. After letting it sit for about 6 hours, it kinda starts to lug when starting.
To me, I think I have a bad battery and will take it back to the store tomorrow to exchange, but is there some way I can check to see if there is a parasitic power drain when the key is shut off?
Another thing.
When I jump started it before I swapped out to the new battery....the truck wouldn't shift out of third gear.
This AM, after I jump started it, it stayed in 5th gear. I re-started the truck and it shifts fine.
My problem is that I'm leaving in a week for vacation and I don't want to sweat the truck not starting whenever I need it to.
  • It was an original Motorcraft battery, 4 years old and a red dot was showing in the battery, plus they tested it an confirmed that it was bad.
  • You can pull a terminal off of the battery and put a multi meter from the battery to the terminal and see how much loss you have.
    They will load test the battery anyway when you take it back and they will tell you if it's a battery problem or not.
