bob213
Apr 30, 2013Explorer
yankeeslover wrote:
arghhhhh. maybe I wasted $40.00 on a charger then...I can probably take back to the store. I just figured that other then when im at a campground, im more likely to have the charger plugged in then the camper itself.. I thaught the camper would take days to charge it, oh well, im learning. does the charger in the camper overcharge though? or does it stop charging when battery is full?
Not all converters are created equal....If you have a fairly new converter it may have a 3 stage system that will go into float once charged. The older models, especially WFCO do not. It's pretty cheap to upgrade to a good 3 stage converter. Check out www.bestconverter.com if you want to go that route.
44,056 PostsLatest Activity: Nov 19, 2013
