bikendan
Apr 30, 2013Explorer
yankeeslover wrote:
arghhhhh. maybe I wasted $40.00 on a charger then...I can probably take back to the store. I just figured that other then when im at a campground, im more likely to have the charger plugged in then the camper itself.. I thaught the camper would take days to charge it, oh well, im learning. does the charger in the camper overcharge though? or does it stop charging when battery is full?
as has been said before, you have a nearly new trailer, that has the latest 3 stage converter, which works just like your battery charger.
leaving it plugged in at home, is not very different than having the pulled-out battery hooked to a separate battery charger.
just a lot less work of pulling it out and putting it back in.
44,056 PostsLatest Activity: Nov 19, 2013
