mobeewan
Oct 21, 2017Explorer
New compact 5000 BTU air conditioner coming next spring
Hopefully in the next few months I'll be able to begin my enclosed utility trailer / mini camper conversion project. I haven't decided on a rooftop air conditioner or using a 5000 to 7000 BTU home window unit mounted on a sliding tray with a baggage hatch mounted to the side wall of the trailer to cover the opening when the tray in slid inside.
Then I came across a YouTube video for a new type of portable 5000 BTU air conditioning unit to be introduced next spring. Looks like it has interesting potential for the possible use in travel trailers as a supplemental air conditioning unit in lieu of a indoor upright portable. One could easily make an adapter so that the unit could be mounted through some existing travel trailer windows. It would require removal of the sliding accordian window filler sections and cutting out the adapters so that you could use the four screw holes of the basic frame portion to mount to the adapter.
For my use I could install a small baggage door, remove the accordion portion from the frame and mount the rest of the frame from the inside of the opening.
Noria 5000 BTU portable window air conditioner
