Hi all....over the past few months i have been on this forum with a bunch of questions re tv's...yall have been a tremendous help. Just took delivery of a 2015 gmc 3500 denali...duramax..4wd. srw.....
Just make sure you check on the height of the top of the truck rail off the ground. Then when you look at 5th wheel trailers you need to add about 6 inches when you measure height of overhang above grade when trailer is level. To make sure you have proper clearance.
For years the truck mfg. seem to think the higher is COOLER, and if you look at an older used trailer you could have a problem.
