Cummins12V98
Jun 25, 2013Explorer III
Magnum164 wrote:Cummins12V98 wrote:
Running lower pressures based on weight on tires is perfectly acceptable!
Not disagreeing. Just saying there is a limit and should be careful. As I originally pointed out, one of my friends almost lost his truck due to low tire pressure on a wet road. I would say probably also depends on type tire and tread. The tire tread is designed to move water out from under the tire, to low a pressure and it can't move the water and can hydroplane...
Guess being a designer I have to analyze things to much:)
And with that I will bow out and keep my pressure at what the truck/tires is rated for.
There is a limit that the tire will not perform within specs. If you read the inflation/load charts there are minimum numbers listed.
I run air pressure based on weight and I easily get 100-120K on Michelins or BFG's on my 98 RAM 4X4 2500.
