Hi i am thinking about ordering a new Denali dually with either a bigfoot camper or northern -lite Question is it better to get a I think a 7.30 or a 4.10 gears for the truck rear end, what is t...
I had 2000 F250 with 3.xx differential and 250HP Powerstroke pulled 18,000 lb trailer on overdrive just fine. I am shopping around for dually and looking for lowest differential possible. The only issue is that with low differential and 2WD your low gear might be too high, but with 4WD you will have transfer case changing gearing.
